CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
No Slip Walls
5 REPLIES 5
inventorlover
1076 Views, 5 Replies
No Slip Walls
How would I add surface roughness to walls in a CFD analysis?  As far as I can tell, free slip is default.
Thank you!
5 REPLIES 5
OmkarJ
in reply to: inventorlover
When you define materials for your domains, there is a option for it. Second last, if I remember correctly
OJ
Royce_adsk
By default all walls are considered no-slip (0 Velocity at the wall).  You can add extra roughness from there as indicated above.  From my perspective most industrial applications do not need this setting adjusted.
-Royce
Royce.Abel
Technical Support Manager
IanGalang
anyone can help?? pleasee
now, i;m confuse too, where to set a roughness wall, because i can't define the wall in boundary condition
thankss
OmkarJ
in reply to: IanGalang
As indicated in the post above, when you define material for your domain, there is an option to specify wall roughness. You can't define wall in boundary condition because any unspecified surface is no-slip wall with zero roughness by default
You can always find information, if you look in help documentation:
http://wikihelp.autodesk.com/Simulation_CFD/enu/2013/Help/0138-The_Proc138/0230-Setup_Ta230/0236-Mat...
OJ
IanGalang
in reply to: OmkarJ
thanks omkar, i found it
