CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
No Simulation CFD button in Revit
9 REPLIES 9
Message 1 of 10
904 Views, 9 Replies
I am unable to launch SimulationCFD from within Revit as no SimCFD button appears in Revit.
I have tried the workaround here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19973972&linkID=18154757
But there is no .addins file in the folder specified.
I am using educational license of SimCFD 2013 and Revit 2013 on windows 7 64 bit. Revit was installed after SimCFD -does that make a difference? The launch button does appear in Inventor.
please help as I would like to demonstrate to my students the integration between BIM & CFD
9 REPLIES 9
Message 2 of 10
Jon.Wilde
Try running SimCFDconfig.exe (right click and run as admin)
Message 3 of 10
in reply to: Jon.Wilde
Hi Jon,
Thanks for your reply.
I've tried this and when I get to the dialogue box to select CAD system, all the CAD options except Fusion 2013 are greyed out. Unclicking Fusion 2013 doesn't make them active.
It appears have a "student license" which I didn't realize is different from an "educational license" could this be the reason?
Message 4 of 10
Jon.Wilde
Files are now located in the marked solution of this forum post.
Maybe you needed to run the CFD install as admin (with a right click) and this folder could not be added? Worth a go possibly although try this first.
Message 5 of 10
Hi Jon,
This worked using the manual workaround mentioned in my first post.
Thanks a lot for your help.
Message 6 of 10
Jon.Wilde
Perfect, thanks for letting me know.
Jon
Message 7 of 10
I am having the same issue, can someone upload the .addin file again or cut and paste the text.  The dropbox link to the ,addin file is dead.  Thanks
Message 8 of 10
Jon.Wilde
Message 9 of 10
Thank you very much for your fast help.  This worked and I am all set.
Message 10 of 10
Royce_adsk
Please reference the support center solution on this topic.  There is a download link in the article if you do not have the folder available to you.
Royce.Abel
Technical Support Manager
