Discussion Groups
Simulation CFD
Member
shroe
No Simulation CFD button in Revit
367 Views, 9 Replies
10-13-2012 11:45 PM
I am unable to launch SimulationCFD from within Revit as no SimCFD button appears in Revit.
I have tried the workaround here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19973972&linkID=18154757
But there is no .addins file in the folder specified.
I am using educational license of SimCFD 2013 and Revit 2013 on windows 7 64 bit. Revit was installed after SimCFD -does that make a difference? The launch button does appear in Inventor.
please help as I would like to demonstrate to my students the integration between BIM & CFD
Please use plain text.
Product Support
wildej
Re: No Simulation CFD button in Revit
10-14-2012 01:05 PM in reply to: shroe
Try running SimCFDconfig.exe (right click and run as admin)
Jon Wilde
Member
shroe
10-14-2012 06:24 PM in reply to: wildej
Hi Jon,
Thanks for your reply.
I've tried this and when I get to the dialogue box to select CAD system, all the CAD options except Fusion 2013 are greyed out. Unclicking Fusion 2013 doesn't make them active.
It appears have a "student license" which I didn't realize is different from an "educational license" could this be the reason?
Product Support
wildej
10-15-2012 02:06 AM in reply to: shroe
Files are now located in the marked solution of this forum post.
Maybe you needed to run the CFD install as admin (with a right click) and this folder could not be added? Worth a go possibly although try this first.
Jon Wilde
Member
shroe
10-16-2012 01:22 AM in reply to: wildej
Hi Jon,
This worked using the manual workaround mentioned in my first post.
Thanks a lot for your help.
Product Support
wildej
10-16-2012 02:25 AM in reply to: shroe
Perfect, thanks for letting me know.
Jon
Jon Wilde
New Member
MSahm
10-28-2012 12:54 PM in reply to: shroe
I am having the same issue, can someone upload the .addin file again or cut and paste the text.  The dropbox link to the ,addin file is dead.  Thanks
Product Support
wildej
10-29-2012 02:16 AM in reply to: shroe
Jon Wilde
New Member
MSahm
10-29-2012 06:23 AM in reply to: shroe
Thank you very much for your fast help.  This worked and I am all set.
Product Support
Royce_adsk
11-02-2012 06:22 AM in reply to: MSahm
Please reference the support center solution on this topic.  There is a download link in the article if you do not have the folder available to you.
Royce Abel
