CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Multiple Fan System
1 REPLY 1
pwilkins
527 Views, 1 Reply
Multiple Fan System
I am trying to run a simulation with two identical fans operating in parallel, pulling air through an enclosure.  In theory, this should double the volumetric airflow through the enclosure.  However, what I am seeing is one fan operating on its fan curve at an expected p and Q, while the other fan is effectively not functioning.  It's p value is high and the Q value very low, and the values are not even on the fan's operating curve.
I have double checked all boundary conditions, input flow directions, and materials.  They are all as they should be.  Have you ever observed this in your models?  What is causing this?  How do I fix it?
1 REPLY 1
Royce_adsk
in reply to: pwilkins
I would suggest that you check out the following first:
  1. Double check the units of the fans
  2. Double check flow direction
  3. If the fan material is the same for both make 2 different materials (change the name, but same properties) and apply 1 material to each fan.
  4. Make the mesh uniform for the fans and confirm that you have at least 4 nodes going through the thickness of the fan.
  5. Contact us in support outside of the forum and we can take a look at it on our end.
Thanks!
Royce
Royce.Abel
Technical Support Manager
