I was wondering if it is possible to merge two simulation in SimCFD. More specifically;
1) If I have two separate cfdst files that have used the same geometry but different mesh/fluid properties, can I add the one simulation as a Scenario in other simulation, such that both are present in the same Design Study?
2) And if the two cfdst files use different geometry, can I add one simulation as a Design Study to another simulation such that both are present in same cfdst as two Design Studies?
Omkar
Solved by Royce_adsk. Go to Solution.
Hi Omkar,
There is no method to merge design studies.
