I've attached a T-P-density chart of my fluid. Change in density is essential to the analysis working properly. What are the recommendations on how to plug this in. This isn't my forte, so any assistance would be appreciated. Thanks.
--Scott
Hi Scott,
What fluid or common similar fluid are you showing here?
It is a refrigerant. I've started to make some assumptions by plotting some of the properties specific to my conditions. Typically for any given temperature, my working pressures will change the density, Cp, or conductivity from 1% to 25%. Because my analyses change temp and pressure at the same time, its certainly important for these properties to be good.
