Discussion Groups
Simulation CFD
Active Member
jvbrad
Licensing question for cluster
536 Views, 6 Replies
10-14-2011 01:55 AM
Hello all,
  CFdesign had the "HPC module", which was required for >4 cores (single system or cluster). The HPC module requirement seems to have been removed from Simulation CFD 2012. Can anyone tell me what the licensing requirements are now for a cluster? Do you just need a single solver license for the head node, regardless of the number of cores/nodes the cluster has in total?
Many thanks,
James.
Please use plain text.
Product Support
Royce_adsk
Re: Licensing question for cluster
10-14-2011 08:23 AM in reply to: jvbrad
Hi James,
You are correct. The license requirements for the HPC module are now included with the solver licenses and a seperate license is no longer needed.  CFD 2012 will support 2^n cores on the machine that you are using out of the box.
-Royce
Royce Abel
Active Member
jvbrad
10-14-2011 10:16 AM in reply to: Royce_adsk
Thanks Royce. Sorry I'm being a bit dumb - when you say it supports 2 to the n cores "on the machine you are using" could you clarify what you mean (is n the number of solver licences?) For example, let's assume I have a 4 node cluster, each node has 4 cores - so 16 cores in total. Will a single solver license on the head node suffice, or are you saying we need 4 licences on the head node (2^4) to cover 16 cores?
James.
Active Member
jvbrad
10-18-2011 08:20 AM in reply to: Royce_adsk
Hi Royce - any chance of an update on this please? What is "n" when you say that CFD 2012 will support 2^n cores?
James.
Employee
derrek.cooper
10-18-2011 08:32 AM in reply to: jvbrad
Hi James.. we will leverage chip sets that are 2^n # of cores (4, 8, 16).. So chips with 6 cores, we will use 4 cores..
Active Member
jvbrad
10-18-2011 08:37 AM in reply to: derrek.cooper
OK I see, many thanks for explaining that Derrek.
Do you have any info on whether a cluster requires more than one license, or will a single solver license (installed on the head node) cover all available cores (ie: including those on the compute nodes too)?
James.
Active Member
jvbrad
10-20-2011 04:18 AM in reply to: jvbrad
Just replying to my own question ... no extra licenses are required for a cluster vs a single workstation. Good news!
