CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
License problem
4 REPLIES 4
sveinn
882 Views, 4 Replies
License problem
Mac address on the license server has been changed.
What should been done to fix it?
Tags (1)
4 REPLIES 4
TravisNave
in reply to: sveinn
If it is a virtual machine, hard code the license file in your virtual NIC back to match your LIC file or you will continually have the same problem.  If it is a physical machine and you changed the network card or motherboard, then you should probably just get a new license file generated to reflect the change.
Please call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
1-800-551-1490 > Option 1 (English) > Option 2 > Network
You will need to provide your serial number and new MAC of the license server.
You will get better responses in the network licensing forum for these types of requests.  Thanks!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
sveinn
in reply to: TravisNave
Hello
It is a license server hos Danfoss that has got a new MAC adress.
I need new license fil for our Program
See Attachement
Sveinn
Edited by
Discussion_Admin
sveinn
Changes were made to license server here at Danfoss causing that the license does not work. I can not create a new license file on the website since it has been done on this contract.
Can I get permission for a new license file on this agreement (110000434892)?
Sincerly
Sveinn
Edited by
Discussion_Admin
TravisNave
in reply to: sveinn
I went ahead and registered this seat for you.  You should have it in your email now.
I will also PM you the license.
Autodesk Forums:
