Discussion Groups
Simulation CFD
matthew.brown
Re: Inviscid Analysis
01-19-2012 07:39 AM in reply to: matthew.brown
Not perfect, but close!
Please use plain text.
matthew.brown
01-19-2012 09:08 AM in reply to: matthew.brown
Royce,
Another issue.  I tried to do this with some different geometry.  I used the same settings, except the analysis is no longer axisymmetric but rather 2D cartesian with multiple bodies.  Instead of the high velocity flow at the wall I am now seeing very low velocity flow at the wall, almost as if there were a boundary forming.   I have attached my share file, if you have a second to look it over I would appreciate it.Screenshot.jpg
matthew.brown
01-19-2012 09:32 AM in reply to: matthew.brown
Here are the XY coordinates for data extraction.  FYI:  the cp's I gave in the spreadsheet were calculated from the velocity magnitude (rather than the calculated cp).    cp= 1- (v/V)^2  and V=1 m/s so cp = 1 -Vmag^2.
Product Support
Royce_adsk
01-19-2012 09:57 AM in reply to: matthew.brown
Matt,
Turn off the slip boundary conditions for the potential flow simulation.  That is degrading the results.  Go back and try your other problem again after removing the slip boundary conditions and see if that helps with the comarison to your benchmark.
I would also consider changing the edge mesh around the profiles to 3600 elements with no biasing.  Since we have a 2D model that solves in 1 iteration, we might as well increase the mesh around the profiles.
-Royce
Royce Abel
matthew.brown
01-19-2012 10:54 AM in reply to: Royce_adsk
Beautiful!  Thanks again.
