What are the interface controls with Autodesk Simulation CFD 2012? Ctrl+right click no longer hides a volume or surface. Where do I find a listing of the new controls?
Solved by Royce_adsk. Go to Solution.
Solved by derrek.cooper. Go to Solution.
depending on the "mode" you are using, controls can either be reflective of the CAD system or native to CFD. "Hiding" or "blanking" volumes is the middle mouse..
After installing the new version your preferences were not transferred over. To change your preferences go to File_Preferences_User Interface. Under the navigation tab you will probably want to change it to the Solidworks type.
Here is more help in the online users guide:
