Discussion Groups
Simulation CFD
Re: Installation Problem - Help me
07-03-2012 02:29 AM in reply to: Royce_adsk
actually i unistalled the autodesk and then i again installed it.now its working fine
Please use plain text.
07-03-2012 02:31 AM in reply to: apolo.vanderberg
thank you very much dude
07-03-2012 07:55 AM in reply to: apolo.vanderberg
now the problem is when i am launching autodesk cfd simulation from solid works it is not even responding
Product Support
Royce_adsk
07-03-2012 08:05 AM in reply to: hareesh.kalyan
Could you post your log file?
It is located here
C:\Users\username\AppData\Local\Autodesk\Simulation CFD 2013\Simulation CFD.log
Royce
Royce Abel
Product Support
Royce_adsk
07-03-2012 08:07 AM in reply to: hareesh.kalyan
When testing the launching from Solidworks follow these two steps first
1) Need to launch from a local drive.  Launching from the network can cause issues.
2) Test with something simple like a block first.
-Royce
Royce Abel
07-03-2012 08:16 AM in reply to: Royce_adsk
i sending the file.plese look into it thank you,
07-03-2012 08:17 AM in reply to: Royce_adsk
i am sending the log file
07-03-2012 08:39 AM in reply to: hareesh.kalyan
even though i try with the blocks, i couldnt launch it.
actually when launch the autodesk cfd simulation in active mode in solid works it is not responding.
mh
Active Member
mh
07-04-2012 05:42 AM in reply to: hareesh.kalyan
Hi
Have tried to install and run CFD with other Adesk software. Tried everything you have mentioned here and start even a topic ( http://forums.autodesk.com/t5/Installation-Licensing/Cannot-initialze-License-manager-ADLM-startup-f... ) and did everything is mentioned there. Nothing works for me so PLEASE HELP:
Today I installed a new HD with fresh windows7 installation and first Software is CFD. I attach some pictures and logs please se if you can help me.
mh
Active Member
mh
07-04-2012 05:43 AM in reply to: hareesh.kalyan
Hi again,
As you cad upload only 3 files here is the rest.
