CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Installation CFD2012 problem
5 REPLIES 5
jmc
Observer
875 Views, 5 Replies
I've registered CFD Motion and Connector Inventor, increment are in lic file. Lmtools diag is correct. When starting CFD there is an error. By activating the diagnostic I see this message:
It seems CFD is looking for Solid Edge connector, this product is NOT installed on the PC.
The Licpath.lic is as explained in installation guide.
CFDconfig.log shows no SolidEdge found.
Any idea?
Thx
5 REPLIES 5
marco.mueller
in reply to: jmc
have you also registered the "Design Study Environment", which is basically the license for the interface? It looks as if it does not find this increment.
Do you have the Solid Edge CAD connection? If this was missing you should be nevertheless able to start the software, though you will not be able to open a design study based on a Solid Edge geometry.
Marco Müller
Product Support Specialist
Digital Simulation
Autodesk, Inc.
jmc
Observer
in reply to: marco.mueller
No I've registred 2 products: CFD Connection for Inventor and CFD Motion.
I won't have any third serial number!
Solid Edge is not installed on the computer,
marco.mueller
in reply to: jmc
If you have not received a serial number for this you should create a support request at the Subscription Center, so that we can deliver it to you.
Marco Müller
Digital Simulation
Autodesk, Inc.
jmc
Observer
OK. Thx.
I tried tos end you a private message about the request, but server gives an error due to ambiguity names...
Is tehre an other manner to contact you?
reeses
in reply to: jmc
Send me an email to scott.reese@autodesk.com and I'll get you to the right folks.
Scott
