CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Importing mesh - successfully
7 REPLIES 7
Message 1 of 8
OmkarJ
525 Views, 7 Replies
I tried to import dat mesh file earlier (that was exported using ICEM-CFD). SimCFD recognizes the format and I see the geometry, but when I try to run it, I get the message that says bad elements formed, reduce enhancement etc. But infact, mesh enhancement is not used in imported meshes!
Can someone suggest a workaround?
OJ
7 REPLIES 7
Message 2 of 8
Royce_adsk
in reply to: OmkarJ
Hi Omkar,
Could you see if a simple model like a pipe fails as well?  If that does could you post that to the forum?  I can test it out on my end.
Royce
Royce.Abel
Technical Support Manager
Message 3 of 8
OmkarJ
in reply to: Royce_adsk
Royce
I have attached the dat file here http://we.tl/MXiYr7XvB6
It is a wedge for an axisymmetric simulation.
Do let me know your findings.
OJ
Message 4 of 8
Royce_adsk
in reply to: OmkarJ
Hi OJ,
I do see the same issue that you found, but just so you know since you called it a 2D analysis.  When setting up a 2D analysis for CFD you will need to define it with only 2D elements and they must be defined on the XY plane.
I am not sure why this specific model isn't working, but to do some basic troubleshooting could you supply a 1 part model that is a simple block that is meshed?
Royce
Royce.Abel
Message 5 of 8
OmkarJ
Royce,
I am familiar with 2D modelling in SimCFD. This mesh was earlier created for 2D analysis in CFX, which eventually works only with 3D geometries even for 2D simulations. Hence the wedge. It was a handy mesh available to me and was small, so posted.
I have attached a meshed cube. http://we.tl/orxnwJQXNm
Let me know how it goes in troubleshooting.
OJ
Message 6 of 8
Royce_adsk
in reply to: OmkarJ
OJ,
There are a few section in your .dat file that could be an issue.
I am familar with seeing the GRID, CQUAD4, and CHEXA sections, but the CBAR and PSHELL I am not familar with
One thing to take into account are the element types that we support:
http://wikihelp.autodesk.com/Simulation_CFD/enu/2014/Help/0532-User_s_G532/0698-Process698/0872-Resu...
Does ICEMCFD provide any option for when you generate this file?
-Royce
Royce.Abel
Message 7 of 8
OmkarJ
Royce,
I do not have access to ICEM CFD currently, but I can look into the documentation and will let you know if Nastran dat afile can be generated using one of the element types you support.
I have a question, in SimCFD documentation, it is mentioned that only three types of meshes are supported, namely, dat, unv and nas. But in the link you just gave me, it shows many other types. I reckon these types are actually used to extract SimCFD results out to use as boundary conditions in FEA tool. But will the mesh in one of these format be supported for SimCFD as well?
Regards
Omkar
Message 8 of 8
Royce_adsk
in reply to: OmkarJ
Hi OJ,
There are many more option to export to FEA vs mesh import types. I only provided that link because it is the only location in the documentation that discusses supported element types.
-Royce
Royce.Abel
