I have two objects made of different materials touching each other. I would like to set a certain thermal contact resistance (with the unit of m^2.K.W(^-1)) for the shared area between two objects. How can I do it in Simulation CFD?
Thanks.
Solved by dousti. Go to Solution.
That is correct!
You can also use surface solid materials and define a thickness using either conductivity or resistivity as the material definition. I typically prefer that approach.
Best regards,
