Solved by Jon.Wilde. Go to Solution.
This might be because you are using a symmetry boundary condition possibly?
Is your building sealed or are the external air volumes and the internal one single connected volume?
It might be worth you sharing your CFZ (supprt file) at this stage if you are able.
Kind regards,
Jon
Hi jon,
I really want to send my CFZ file but it is more than 1.5 MB so I can not attach it here.Is there any way for me to send this file(2.5 MB). I have used temperate boundry condition on sky, maybe because of that the software considered it as symmetry boundry condition so how can I set temperature on sky volume?
I have some urban blocks in the middle of dome as the sky and the cubic volume as external air want to find out air movement, temperature and radiation around the urban blocks.
I really thanks you about help.
Best Regards,
Hani
I will send you a pm
OK Hani, I have the model, thanks for sharing it.
I can tell you that the multiple symmetries are part of what is causing the error but there are many issues with Boudary Conditions - please could you mark up an image of the model, explaining what the goal is, as I cannot interpret it from just the model alone.
One thing you should know, is that we cannot assign internal Surface Boudnary Conditions - these all need to go.
Kind regards,
Jon
Hi Hani,
Thank you for the file - this is getting there.
There is no gain in having an air-dome within a large cuboid though - I suggest you delete the dome and just have a cuboid air domain.
There is no need to apply slip/symm to the walls where you have pressure and velocity - only the side walls where you wish to remove the frictional effects.
If you assigning a temperature to the floor - use the entire floor. It is also best to add a thickness to the ground and assign the temp beneath this rather than on top - as right now we are preventing the ground from heating up at all by fixing it's temperature.
I hope that helps you move forwards.
Kind regards,
Jon
Hi Hani,
Nope, just use Boundary Conditions. Initial Conditions are only used for transient analyses, for instance, if we are looking at something heat up over time and wish to set an intial temperature on the volume.
Kind regards,
Jon
Dear jon,
If I want to study the the airflow inside this model, what boundary condition should I set for windows.for the windows that air flow in ,I think I should set the velocity but for the windows in patio that I know that the air goes out what should I do?How can I estimate the wind speed in each floor?I want to see air floe in basement and last floor.
Best regards,
hani
