Discussion Groups
Simulation CFD
Active Contributor
kaiwei
Heat Release Rate
445 Views, 5 Replies
11-14-2012 01:21 AM
Is CFDesign able to show the Heat Release Rate (measured in kilowatts or megawatts) in its results? Thank you.
Please use plain text.
Product Support
apolo.vanderberg
Re: Heat Release Rate
11-14-2012 11:29 AM in reply to: kaiwei
kaiwei,
Yes when we run thermal models we will compute the amount of energy released from a component.
What I might suggest is to look at any of our electronic thermal example models and step through them as you would be able to see the types of output from within Simulation CFD (CFdesign 2011 and prior is the legacy product name prior to being acquired by Autodesk)
Apolo
Active Contributor
kaiwei
11-15-2012 10:22 PM in reply to: apolo.vanderberg
Firstly, I was wondering if Simulation CFD 2013 is able to do what Fire Dynamics Simulator (FDS) is capable of? Please refer to the attached picture for what I am referring to.
Secondly, I was wondering if Simulation CFD 2013 is approved by any Fire Safety Board for use? If so, are there any limitations. Thank you.
Product Support
apolo.vanderberg
11-16-2012 05:35 AM in reply to: kaiwei
kaiwei,
   Please take a moment to read through our Wiki Help (heres a link to our Smoke Modeling for fire safety)
This  should answer man of your questions.
Apolo
Active Contributor
kaiwei
11-22-2012 01:25 AM in reply to: apolo.vanderberg
Hi Apolo,
We have verified the capabilities for Smoke modelling but users are asking for a simulation of items combusting. For example, can Simulation CFD simulate the combustion of a wooden table in an enclosed room? From the simulation, the user would like to know the Heat Release Rate.
Product Support
Royce_adsk
12-03-2012 01:50 PM in reply to: kaiwei
Simulation CFD cannot model combustion.
-Royce
Royce Abel
