Is CFDesign able to show the Heat Release Rate (measured in kilowatts or megawatts) in its results? Thank you.
Solved by Royce_adsk. Go to Solution.
Solved by apolo_vanderberg. Go to Solution.
kaiwei,
Yes when we run thermal models we will compute the amount of energy released from a component.
What I might suggest is to look at any of our electronic thermal example models and step through them as you would be able to see the types of output from within Simulation CFD (CFdesign 2011 and prior is the legacy product name prior to being acquired by Autodesk)
Apolo
Firstly, I was wondering if Simulation CFD 2013 is able to do what Fire Dynamics Simulator (FDS) is capable of? Please refer to the attached picture for what I am referring to.
Secondly, I was wondering if Simulation CFD 2013 is approved by any Fire Safety Board for use? If so, are there any limitations. Thank you.
kaiwei,
Please take a moment to read through our Wiki Help (heres a link to our Smoke Modeling for fire safety)
This should answer man of your questions.
Apolo
Hi Apolo,
We have verified the capabilities for Smoke modelling but users are asking for a simulation of items combusting. For example, can Simulation CFD simulate the combustion of a wooden table in an enclosed room? From the simulation, the user would like to know the Heat Release Rate.
Simulation CFD cannot model combustion.
-Royce
