Discussion Groups
Simulation CFD
Member
ckasunic
Having trouble launching CAD model into Simulation CFD from Inventor
388 Views, 2 Replies
04-04-2013 08:15 AM
When opening a CAD model into Inventor, the option to launch into Simulation CFD is not given, while the option to launch into Simulation Mechanical is. Any ideas how to fix this, or how to launch my CAD model into CFD a different way?
Please use plain text.
Distinguished Contributor
ilyas
Re: Having trouble launching CAD model into Simulation CFD from Inventor
04-08-2013 08:36 PM in reply to: ckasunic
Inside Inventor, check whether the simulation CFD add-in is loaded or not (Tools>Options>Add-In). If you are using the new CFD 2014, then you can directly open inventor .iam and .ipt files from within CFD.
Regards
Ilyas
Product Support
Royce_adsk
04-09-2013 07:58 AM in reply to: ckasunic
Run this program to try to fix your CAD Connections:
C:\Program Files\Autodesk\Simulation CFD 2014\SimCFDConfig.exe
You may need to select 'run at administrator' when running this setup program.
-Royce
Royce Abel
