Discussion Groups
Simulation CFD
*Expert Elite*
Dan.M
Accepted Solution
Flow Rate
179 Views, 5 Replies
04-07-2013 01:32 AM
Hello
i am checking the flow on a system. The BC are Pressure only. At inlet P=1bar and outlet is gage.
Can i recieve the flow rate from the analysys?
Dan
Please use plain text.
*Expert Elite*
OmkarJ
Re: Flow Rate
04-07-2013 10:21 AM in reply to: Dan.M
Yes you should be able to.
If it is a simple flow (pipe or parallel plates etc) you can get the flow rate analytically using Poiseuille equation as well.
OJ
Product Support
wildej
Re: Flow Rate
04-08-2013 01:06 AM in reply to: OmkarJ
Agreed.
Be sure to run Advection Acheme 5 also, important if we have no flow rate to drive the fluid. (Solve -> Solution Controls -> Advection)
Jon Wilde
Product Support
Royce_adsk
Re: Flow Rate
04-08-2013 11:27 AM in reply to: Dan.M
There are many ways to determine the various states at the openings of a model. Using the plane bulk-calculator or the summary file are the typical workflows.  I would suggest that you start with looking at the summary file.
Royce Abel
*Expert Elite*
Dan.M
Re: Flow Rate
04-08-2013 11:54 PM in reply to: Royce_adsk
Great,
Thanks. Although the units there are something that you would need to change.
When I say "you" I mean AD.
Dan
Product Support
Royce_adsk
Re: Flow Rate
04-09-2013 06:59 AM in reply to: Dan.M
When you use the summary file a lot it really helps to think about your system units before you run your model to get the default result units as close as possible to what you want and/or away from units that you hate.
Cheers!
Royce
Royce Abel
