Discussion Groups
Simulation CFD
New Member
brandonslien
First simulation help;
204 Views, 0 Replies
03-15-2012 12:15 PM
When i run the simulation it gets past verifying the model and in analysing where i get the following  warning: Warning! quit for zero loading:
 Ive read some other posts with similar problems  and have solved many issues already to get this point....
I have attached the ipt file.
I defined the input velocity (both cylinders on one side)  and inlet/outlets on the other. I have tried meshing it finer, and have excluded the inlet/outlet surfaces as well as prescribed velocity surfaces from the mesh.
The only other problem i think i could have is I am unsure fully how to set up the simulation, and the add/row/column and what it all means. I kind of just based it off of others/tutorials.
It doesn't always save, but im using water as the fluid material.
Thank you for your help
My email is brandonSlien@gmail.com as another way to contact me.
Please use plain text.
