Discussion Groups
Simulation CFD
Member
pawel.dudzinski
Accepted Solution
Filling an empty chamber
138 Views, 3 Replies
04-03-2013 12:47 AM
is it possible to simulate how fluid for example water is filling an empty chamber? I was trying to do such a thing but I haven't found any solution yet. As far as I know Autodesk Simulation CFD allows only to indicate where the fluid is at the beginning and then run the simulation. Any ideas?
Pawel
Please use plain text.
*Expert Elite*
OmkarJ
Re: Filling an empty chamber
04-03-2013 04:11 AM in reply to: pawel.dudzinski
It should be possible with Simulation CFD 2014, as I read, it can simulate free surface flows.
OJ
Employee
ryan.arnaudin
04-03-2013 10:41 AM in reply to: pawel.dudzinski
Pawel, check out the documentation for free surface modeling in CFD 2014 -- I think you'll find what you need.
http://wikihelp.autodesk.com/Simulation_CFD/enu/2014/Help/0360-Learning360/0400-Simulati400/0424-Fre...
Member
pawel.dudzinski
04-03-2013 11:20 AM in reply to: pawel.dudzinski
Thank you guys for respond. I've checked the dowload center for students and there is only one simulation cfd software available, is it 2014 version?
