is it possible to simulate how fluid for example water is filling an empty chamber? I was trying to do such a thing but I haven't found any solution yet. As far as I know Autodesk Simulation CFD allows only to indicate where the fluid is at the beginning and then run the simulation. Any ideas?
Pawel
Solved by ryan.arnaudin. Go to Solution.
Solved by OmkarJ. Go to Solution.
It should be possible with Simulation CFD 2014, as I read, it can simulate free surface flows.
OJ
Pawel, check out the documentation for free surface modeling in CFD 2014 -- I think you'll find what you need.
Thank you guys for respond. I've checked the dowload center for students and there is only one simulation cfd software available, is it 2014 version?
