CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Filling an empty chamber
3 REPLIES 3
pawel.dudzinski
437 Views, 3 Replies
is it possible to simulate how fluid for example water is filling an empty chamber? I was trying to do such a thing but I haven't found any solution yet. As far as I know Autodesk Simulation CFD allows only to indicate where the fluid is at the beginning and then run the simulation. Any ideas?
Pawel
3 REPLIES 3
OmkarJ
in reply to: pawel.dudzinski
It should be possible with Simulation CFD 2014, as I read, it can simulate free surface flows.
OJ
Pawel, check out the documentation for free surface modeling in CFD 2014 -- I think you'll find what you need.
http://wikihelp.autodesk.com/Simulation_CFD/enu/2014/Help/0360-Learning360/0400-Simulati400/0424-Fre...
Thank you guys for respond. I've checked the dowload center for students and there is only one simulation cfd software available, is it 2014 version?
