CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
FEA mapping help
5 REPLIES 5
whiteskulleton
642 Views, 5 Replies
FEA mapping help
I am currently trying to export a FEA Mapping to a .unv file that was created with Simulation Multiphysics. Basically I took the Autodesk Inventor and imported it into Multiphysics. I then applied pressure values to the inside of my valve where the fluid contacts it. I then exported the file into a .unv file format. I then ran a simulation in CFD and tried to export the FEA mapping onto the .unv file. (side note: I suppressed all the solids when running the CFD simulation, not sure if this matters). However, I coudn't find the "_newbcs" file that CFD had made. (side note: whenever I pressed the "Map results to BC" button nothing visible happens). However, I noticed that whenever I click the button there is a quick spike in CPU usage. However, I don't think this really means anything.
I also tried playing around with the different flags in CFD with no help. However, I did find that the unv_mesh_flag did work and it exported the file to the root C:/ directory. This could explain why exporting anything through the applications menu gives the error:
Unable to export requested data
Check the following:
1. File permissions and folder privileges
2. Disk space
3. Make sure the file is not in use by another process
Disc space is fine and it is not 3 becuase all programs were closed except CFD. I changed the security of the C:\ directory but it didn't do anything (What I did: gave Everyone full access to the C:\ directory).
Anyways, that was kinda a tangent. I looked in the C:\ directory (along with the folder that contains the CFD senario) and I cound't find the _newbcs file.
Wait, theres more! I checked the Status File in CFD and noticed that the unv_mesh_flag had called 1 thingy (probably a function) from Line 180 of source\cfd_unvmesh.c. However, the unv_out_flag had called 0 functions from "Line -1 of   " (which means that it never called a function).
I have also tried this and couldn't find the .int file. I have also read that Multiphysics does not support FSI. I might be missinterpreting it but I thought that meant that you counld not directly export FEA information from CFD to Multiphysics. So what I am trying to do is a workaround by exporting it into different file formats (If this is not what Fluid-Structure Interation means then please explain why this doesn't work.) So I'm basically out ideas on how to make this work.
Extra Information:
Autodesk Inventor 2013
Autodesk Simulation Multiphysics 2013
Autodesk Simulation CFD 2013
Windows 7 Professional 64bit
Thanks for reading.
5 REPLIES 5
Interesting....I just had the same thing happen to me today!
The FEA Mapping works...I"ve done it in the past.  However, this time, I'm getting the exact same response.  I hit the Map results to BC and see a little blip of activity and nothing more.
I check file paths etc...but nothing seems amis.
What is a drag is that there is no error checking or messages to let the user know what has failed.
Ohh well --
My feeling is that it is just one of those things - a small bug.  I have a request into technical support to see what is what. I really miss the old days when one could just call up the CFdesign folks and get an answer.  It might not be what you wanted to hear but it was quick, fast and efficient.  Now we deal with the godzilla.
When I hear of a solution - I'll let you know.
Cheers,
George
P.S.  CFD 2013
Win 7 64 bit
working with a Femap neu file
nhahn
in reply to: whiteskulleton
Did this ever get solved?  I am experiencing the same thing (with the .inp format)  - I hit Map Results to BC and nothing happens.
Is it a permissions issue?
roypersa2
in reply to: nhahn
I am getting the same result with CFD 2016.
I have put the nastran mesh in any possible folder in order to avoid the error message but nothing happens.
Heeelp please!
Rogelio
A few notes to add here:
If the end goal is to map to Multiphysics, check out the CFD2Mech app published in the AppExchange. This was developed for mapping between CFD and Sim Mechanical (which the process should be similar for Multiphysics) as it just created an Loads file that you can import in and leverage.
Otherwise we do have a few *.xfr logs (as well as some details in the Status file) when you perform FEA mapping that may give insight in to what might have gone wrong.
Did you guys find any solution? I have the same problem!
I am trying to map results into an amsys ".cdb" file, and it just blip and does nothing. Please help!
