Discussion Groups
Simulation CFD
New Member
cpierce223
Export CFD Created Volume to solidWorks/ few other questions
209 Views, 1 Replies
06-19-2012 11:44 AM
Is it possible to create a volume using the CFD tool and export that to solidworks for editing. Or can I edit within autodesk if I only have a simulation key, not the CAD software. In detail, the problem is i want to model a centrifigul pump and I want to eliminate the filets on the water without changing the tube shape. Also I want to use the valute casting to create the volume and than delete it in the CFD but when I click remove it stays, also I surpress it and it stays, just slashes the name bar. Any suggestions?
Chad
Please use plain text.
Product Support
Royce_adsk
Re: Export CFD Created Volume to solidWorks/ few other questions
07-02-2012 02:27 PM in reply to: cpierce223
Hi Chad,
It is not possible to export geometry from Simulation CFD.
You might want to explore Inventor Fusion for geoemtry simplification.
-Royce
Royce Abel
