Discussion Groups
Simulation CFD
Active Contributor
Accepted Solution
Error: "Can't find PSI.DLL" file
212 Views, 2 Replies
04-16-2013 06:49 PM
There is an error while launching .rvt files from Revit 2013 into Autodesk Simulation CFD 2013. The error message is  "Can't find PSI.DLL". Is there a reason for this error? And is there a way to solve it? Thank you.
Please use plain text.
Product Support
Royce_adsk
Re: Error: "Can't find PSI.DLL" file
04-17-2013 08:26 AM in reply to: kaiwei
Try this workflow!  I have had a lot of success using this workflow to get around the psi.dll error message.
1) Create New Project
2) Link to Revit Model
3) Click on Linked Model in Graphic Window
4) Click on Bind Link
5) Include All
6) Save
7) Launch
Royce Abel
Active Contributor
04-25-2013 07:53 PM in reply to: kaiwei
Hi Royce,
Thank you for your help. Your suggestion has worked and we realized that the issue was due a Revit template incompatibility.
