it would be helpfull, if CFD could import and handle real Gerber-Data from ECAD-Designs to simulate the power dissipation of a PCB.
Many electronic drives (E-Bike, E-Car, ...) need a lot of current, which results in heating of a pcb due tue the copper resistance.
For a correct simulation of the heating and cooling of such a pcb it is necessary to import real Gerber-Data.
Alois
Solved by hartogj. Go to Solution.
Thanks Alois. Appreciate the feedback. If there is a sample file you can share as an example of the data you want to work with, can you send it to Simulation.CFD.Enhancements@autodesk.com?
Jon
Hello Jon,
is a sample file (Extended Gerber Data) necessary ?
Will Autodesk this feature implement in the next time ?
Alois
