CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Effect of Humidity in Human Comfort
2 REPLIES 2
441 Views, 2 Replies
Hi!
Currently I'm working on Thermal Comfort of an occupant inside a room varrying humidity in thermal comfort factors (from result qunatity) but keeping Metabolic rate and clothing constant. But as i know, humidity plays a vital role in thermal comfort but here i can't see any major difference.
I created two Scenario and applied 76% humidity to one and 36% to another in the field of thermal comfort factors.
How can i get better result.Any suggestion regarding thermal comfort problem; would be very helpful.
Should I assign humidity in the inlet boundary conditions? Or its okay to change it in the thermal comfort factors from result quantities.
I attached my attemped CFZ file with this post.
Thank you!
2 REPLIES 2
Royce_adsk
What does the same comparison look like with the legend change from -3 to 3 to -1 to 1.
Cheers!
Royce.Abel
Technical Support Manager
in reply to: Royce_adsk
Hi!
Thanks for your reply! I changed the legend into -1 to 1. And its showing like this.
Which is showing slightly cold feeling with higher humidity,is it realistic?
Is my process of changing humidity correct? I changed it from thermal comfort factors in result quantities. Or should i try changing humidity in inlet air boundry conditions? And any recommandation for my meshing?
Thank you very much!
