Discussion Groups
Simulation CFD
Member
ERROR The analysis has stopped because solver had exited unexpected​ly
202 Views, 2 Replies
03-12-2013 02:22 PM
Hello, I have setup a very simple enclosed room with two openings one for supply air and another for return. I have defined all materials for walls and inside air volume and defined the boundary conditions for the supply air of 95 deg and 500 CFM and 0 pressure for the return. I set meshing to autosize. Under Solve I set physics for heat transfer and made sure to set the gravity. Despite double and triple checking the solver fails to run. I get a "the analysis has stopped because solver had exited unexpectedly" error. I have attached the CFZ file for anyone willing to take a look at it. Successfully running this simple scenario will allow me to try and run a more complex scenario for our project. Any help would be appreciated.
Many thanks
Please use plain text.
Product Support
wildej
Re: ERROR The analysis has stopped because solver had exited unexpected​ly
03-14-2013 07:33 AM in reply to: Engineer4Life
Hi, please could you attach the cfz rather than a cfdst (which we cannot open), then one of us can take a look, thank you!
Jon Wilde
Member
03-15-2013 11:20 AM in reply to: wildej
Thanks for the reply. I found out the reason the model was crashing was because I was running the simulation off the company server instead of on the local machine the software is installed. We are normally supposed to do all work in the project folder on the server. Apparently this CFD software requires resources that were not available to it due to insufficient read/write previllages bestowed upon myself and all other employees. I hope others finds this useful and go straight to simulating on the C: drive and save themselves hours of head aches.
Regarding the cfz file. Does it contain all model information that you can open on your end? Where can I find it? I do not see it, are my file extenions turned off in windows explorer?
