Hi I have a CFD 2013 student edition.If after I exited the program after a simulation, when I load the simulation again It doesn't load also the results of the simulation.
Is this because of the license ?
Vlad Martian
Solved by romar_ro. Go to Solution.
Hi Vlad.. This should have nothing to do with the license.
Where is the original CAD geometry coming from and how are you launching it into SIMCFD? You might want to post a support file (File>Save>Share File) to the forum and maybe someone can test it on their end.
The commercial and EDU versions of SIMCFD are essentially exactly the same.
Ok, thanks. Anyway I have discovered where I was wrong. Every time I opend the simulation I piked the wrong file (.CFZ instead of *.cfdst).
Thanks anyway.
