Discussion Groups
Simulation CFD
Member
Does CFD2013 depends on RAM supported by a 32bit & 64bit OS
153 Views, 2 Replies
11-12-2012 02:07 AM
I have upgraded my hardware to 16gb RAM, but it seems windows 7 32-bit utilizes on a max of 4gb so the rest is unusable. I'd like to understand if CFD has a feature to use the actual physical memory of 16GB installed.
Does changing to a 64-bit OS platform have a better impact to utilize the memory RAM for CFD.
Thanks.
Please use plain text.
Product Support
wildej
Re: Does CFD2013 depends on RAM supported by a 32bit & 64bit OS
11-12-2012 04:25 AM in reply to: XPMechEngr
The limitation here is the 32bit OS, there is no way to access it on a 32bit system.
If you move to 64bit then yes, we would be able to access the additional RAM.
Jon Wilde
Member
11-21-2012 07:27 PM in reply to: wildej
Thanks for this info. I've upgraded to 64bit platform and able to utilize all my RAM capacity now.
