Is there a way to setup the View as Orthographic as a default view without going back to the view cube and switching to orthographic?
Solved by Royce_adsk. Go to Solution.
I am not aware of any way to do this, no. Typically the model launches with the same view as the CAD system.
Kind regards,
Jon
You will need to modify your options if you want perspective projective enabled or not. Then close down and reopen Simulation CFD.
That should do it for you!
