CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Default View setup
2 REPLIES 2
csjhun
365 Views, 2 Replies
Default View setup
Is there a way to setup the View as Orthographic as a default view without going back to the view cube and switching to orthographic?
2 REPLIES 2
Jon.Wilde
in reply to: csjhun
I am not aware of any way to do this, no. Typically the model launches with the same view as the CAD system.
Kind regards,
Jon
Royce_adsk
in reply to: Jon.Wilde
You will need to modify your options if you want perspective projective enabled or not.  Then close down and reopen Simulation CFD.
That should do it for you!
Royce.Abel
Technical Support Manager
