I am new to CFD and have figured out the software mostly. I was using one of the hydraulic oil materials Inventor CFD has supplies stock. But for the project I am working on I need to use Therminol 66 as my fluid. I made my own material in the material editior to relfect the theriminol. But when I go to set the enviorment the properties listed are the same properties of the hydraulic fluid. Does anyone know how to chage this?
Any help appreciated.
Can you tell me what mat environment setting UI you are using to change properties? If you go from the dsa bar, there is a mat environment settings dialog to set the scenario level property.
