CFD Forum
Welcome to Autodeskā€™s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Changing steam.dat to ammonia data
1 REPLY 1
434 Views, 1 Reply
I am currently working on a CFD-analysis of some pipes, where I need to use a subsonic solver, which means that I need variable density, which means I need to modify my steam.dat-file to have ammonia-data instead of the default water-steam.
I have more or less figured out how to do it, import to excel from dat-file, change data to ammonia and then export again, (I havenĀ“t exported yet).
But I want to know, that what I am doing is correct.
- which temperature-steps would be sufficient.
- how many values are needed.
- some of the values are divided by numbers like "0.2 25" and "0.4 23", what are their function?
1 REPLY 1
marco.mueller
Both questions seem to be similar?! It depends on how good your results have to be, similar to the mesh resultion or other material properties. As a starting point you can chose maybe a rough assumption with only a few values.
this line (and the others) defines a single isobar for the steam properties. In your example it is the 0.2 psi isobar and 25 temperature values (in the lines beneath) specify the curve.
Marco MĆ¼ller
Product Support Specialist
Digital Simulation
Autodesk, Inc.
