Discussion Groups
Simulation CFD
Active Member
gdais_user
Change turbulence model upon resume?
101 Views, 1 Replies
03-18-2013 06:12 AM
I assume this is a fairly straightforward question:
Can I change the turbulence model upon resuming a CFD analysis?  What sort of disruptions could this cause?  For example, I'm assuming the solver will need some iterations to do the auto-startup if switching from laminar to turbulent?
I have an scenario where the first part will be low flow (in the laminar region), but part two will include bursts of higher flow (into the low-Re region).  I'm analyzing a scalar mixing problem.  I have run part one in both laminar and low-Re turb mode and unfortunately my % volume scalar results are quite different at the end (~ 44% different).  Therefore, I'm unsure about the accuracy of part two run in low-Re turb mode following part one.
Please use plain text.
*Expert Elite*
OmkarJ
Re: Change turbulence model upon resume?
03-19-2013 09:58 AM in reply to: gdais_user
Low Re model requires mesh really fine with Y+ values close to 1, since there are no wall functions. Are you sure about the mesh independence?
OJ
