Dear All
is it necessary to have the impeller (solid) as part centrifugal pump analysis?
I know it can be suppressed, but whether it can helo achieve good results?
Looling forward to your reply
Assuming you are running with a Rotating Region (the best way), no you can suppress it. You can still use the edges of it to add surface refinement to the blade tips too.
Jon
Thanks for your reply by sharing your experience.
My current results are still deviated from the performance curve of the pump. Wondering whether you can share your experience to running such analysis with rotating region to achieve a better accuracy.
3deg/step is just what we have used and know to work well. You could also use 2deg/step 🙂
yes. I have been using either 2 or 3 deg per time step.
Like to ask about the recommended turbulence model to be used? K-epsilon model has been the model. Is it the recommeneded one or others?
As for the meshing requirement, do you use mesh enhancement (with 1, 3, or more layers).
Thanks for yr advice.
If you use the k-e model 3 layers work fine most of the time- but you should ensure that wall Y+ values stay above 12 as the k-e model works best for Y+ values in the range of 12 to 300. The SST model is immune to Y+ values falling under 12, so you can use more layers for better boundary layer resolution. This means more elements, but the SST is more stable and frequently reaches converged solution in steady state cases faster than the k-e model does.
Experiment with the mesh and the turbulence models to find your best combination.
