CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Cannot assign Internal Fan/Pump material
2 REPLIES 2
pwilkins
616 Views, 2 Replies
I am having a problem assigning Internal Fan/Pump material.  At first I thought there was a problem assigning a custom Internal Fan material, but I also tried the default fan materials and they did not work either.
I have never had this problem before and it just started happening out of the blue today.
What might be the issue?  How can I fix it?
2 REPLIES 2
pwilkins
in reply to: pwilkins
Nevermind, I found the problem.  I had assigned two boundary conditions before I had finished assigning all materials.  For some reason this was preventing me from assigning the Fan material.  When I deleted the BCs, I was able to assign the Fan material with no problem.
Royce_adsk
Upon further review it was probably fixed by assigning the fluid parts first before you assign the fans parts.
Royce.Abel
Technical Support Manager
