CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Can the "Points" window be expanded?
4 REPLIES 4
399 Views, 4 Replies
Does anyone know how to extend the "Points" window so the full "Name" description is visiable?
Thanks, Dan
4 REPLIES 4
Jon.Wilde
Hi Dan,
If you cannot do so from the bottom corner of the window, how about sliding just the name column over to expand it?
in reply to: Jon.Wilde
Jon,
The window is not allowing me to grab it's lower corner to expand the window, nor is it allowing me to grab the edge of any column to slide the column over.
Regards, Dan
Royce_adsk
Hi Dan,
Those are fixed windows in the program. I would suggest that you add an idea to the idea station to get this changed.
http://forums.autodesk.com/t5/Simulation-CFD-IdeaStation/idb-p/82
Thanks!
Royce
Royce.Abel
Technical Support Manager
in reply to: Royce_adsk
Royce,
Thanks, I'll do that.
Regards, Dan
