First of all. I sorry for my English is very poor .
I use CFD 2015 64 bit and Inventor 2015
I have problem to Launch Active model CFD in Autodesk Inventor .
1. I can't change Study name in Design study manager .
2. In Panel update design study . I can't click update floder .
3. When I click Launch in dialog box . I not have model in CFD.
but I can use New in CFD program for run model .
Thank you!!
hi bobaa, can you please post a screenshot or shot video of the issue?
Note, to update a design study you must have an existing design study to update. Select at the design study level in the list to open the existing study or add the geometry to a new design in the study. Select at the design level in the list to update geometry for that existing design in the study.
That is a very unique issue. The first thing I would suggest is to close everything down and run the following program.
To run this program correctly right click on chose 'Run as Administrator'
C:\Program Files\Autodesk\Simulation CFD 2015\SimCFDConfig.exe
Lets see if that fixes the issue.
Thanks!
Thank you Royce_adsk. This Pic after I'm right click and chose Run as Administrator in SimCFDConfig.exe file.
But ,It's still the same
Is this Windows 8?
Seems to me to be partly a read/write issue and maybe graphics card/driver?.
What graphics card do you have?
Have you tried to update the driver to the most recent avaiable?
What virus scanner do you have installed?
Can you share the screen of CAD model folder( where the inventor model exists ) and the %temp% folder? I suspect some temperory files are not generated for some permission issue.
You also may try deleting the file “design_studies.info” in the following directory:
C:\Users\[user_name]\AppData\Local\Autodesk\Simulation CFD 2015
