Discussion Groups
Simulation CFD
*Expert Elite*
Can't apply fully developed flow
221 Views, 8 Replies
12-05-2012 01:09 AM
Ok, this is painfully hilarious.  I have a perfectly circular inlet but when I try to apply a fully developed flow condition (volume flow), it doesn't let me apply. When I untick the fully developed setting , only then I can apply the boundary condition. Going back to CAD (Inventor 2012), I can measure the diameter of that inlet boundary, meaning that CAD confirms its circularity, which is the requirement of fully developed flow!
Any thoughts?
OJ
Please use plain text.
*Expert Elite*
Re: Can't apply fully developed flow
12-07-2012 12:54 AM in reply to: OmkarJ
Someone, please?
Valued Contributor
marco.mueller
12-11-2012 06:56 AM in reply to: OmkarJ
Maybe the edge is split? Or not perfectly flat?
*Expert Elite*
12-11-2012 06:59 AM in reply to: marco.mueller
Thanks, at least someone heard! But how to know if the edge is split? The CAD software confirms the circularity as I can measure the diameter. And Geometry Tools in SimCFD doesn't highlight any concern.
Regards
OJ
Valued Contributor
marco.mueller
12-11-2012 07:01 AM in reply to: OmkarJ
go to edge selection method and pick the edge. Then you'll see if it is just one or more...
New Member
12-19-2012 05:56 AM in reply to: OmkarJ
Hallo,
I have the same Problem OmkarJ described. I can't apply fully developed flow as boundary conditon.
I'm using a Student Version of Simulation CFX 2013.
Is this probably the reason why I'm not able to use this function?
Daniel
*Expert Elite*
01-07-2013 01:49 AM in reply to: OmkarJ
Well it's just one edge! I had not been able to apply this boundary condition since ages!
Regards
OJ
Distinguished Contributor
01-07-2013 07:31 PM in reply to: OmkarJ
I suggest you try to export your CAD file to another format, open it in Simulation CFD and apply the fully developed BC.
I tried directly opening my CAD file in Simulation CFD using the Invertor Add-in and faced the same issue when applying the fully developed velocity BC (cannot press Apply on the quickedit dialogue box). For me, the problem only happens for circular cross sections, I experimented with a square cross section and it works fine(as far as applying the BC). For circular cross sections, I exported my CAD as parasolid text and was successful in applying the fully developed velocity BC. I think there might be a problem with the Inventor translations for circular profiles. The problem did not exist for the 2014 Beta version though.
Regards
Ilyas
*Expert Elite*
01-08-2013 12:59 AM in reply to: ilyas
I have lodged the case with subscription center. I will update this thread with any remedy suggested.
OJ
