Discussion Groups
Simulation CFD
mark
CFD2012 Crashes when trying to save
174 Views, 2 Replies
11-01-2012 01:19 AM
I am having a problem with CFD2012. I have a design study with quite a few (17) designs. I have found that when I have a crash, I am sometimes unable to open the design study again: it just crashes repeatedly (Windows message that the program has crashed). The problem I am having now is that I am unable to do anything with this particular design study other than look at the results of only one design. I cannot add designs to it, nor update designs. The only option I have is to open the share file, thus losing all of my results. I have had to do this a few times now, and each time I lose all of the results. As each of the analyses takes two hours or so to run, it is time consuming and leaves me with a fragmented set of results, in scattered files.
What I would like to know is:
1. Is there a general solution to this behaviour?
2. Is there a way to extract results out of this design study and save them seperately? Then I could collate them again into a design study. I cannot use the "Save Share File" option: No matter what contents type I select, or which designs I check or uncheck, it crashes the minute I press the "Save" button.
I have plenty of space on my drive. For what its worth, my hardware is a MacPro Retina (Solid state drive), running W7.
Please use plain text.
Product Support
Royce_adsk
Re: CFD2012 Crashes when trying to save
11-01-2012 08:45 AM in reply to: mark
This will happen sometimes once the design study is too large for your system.  I would try to reduce the number of designs in your design study to around 6.  This count really depends on the specs of your computer and the size of your models. I have seen some users have dozens of 2D models since they are so small.  With that in mind it is hard to give you a hard number.
Reduce the size of your design study.
If you go into the folder structure (windows) of your design study, delete the last solved for analysis to free up some memory.  This will typically fix what might have been corrupted from a memory standpoint.  I always make a backup of my design study folder as a backup so I don't lose my results while i am troubleshooting this issue.
Use your _support.cfz file to recover the above deleted runs to rerun in a new design study.
Until you can actually save your model you won't be able to do a save share file.  The save share file is the intended workflow for what you have described above.
Royce Abel
mark
11-01-2012 09:09 AM in reply to: Royce_adsk
Thanks. Yes, I think that is the problem: when I delved a bit deeper I saw that Windows had written huge memory dump files (over 1GB each) which were reducing my disk space below the plenty of GB's which I thought I had. So that all ties up. Thanks for the great and prompt support. Mark Marshall mark@outside.co.za 083 499 1114
