CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
CFD for boat hulls
8 REPLIES 8
Message 1 of 9
michaelperry2011
2030 Views, 8 Replies
CFD for boat hulls
I have designed a boat hull and can export it to .stl, .igs, and eventually Inventor formats. Is there a way to model a hull moving through water using this software.
I seem to be hitting quite a learning curve, and the documentation that Autodesk is providing is marginal, at best.
8 REPLIES 8
Message 2 of 9
Yes,
this would be similar to any other external aero application only you would have to combine it with our Free Surface capability (in 2014).
Boat would be caded in the middle of a large domain - all assigned as water
Lower half of the domain would be assigned Height of Fluid Initial Condition as well as Compnent Velocity (Vx / Vy /Vz)
Boundary condition to dictate the velocity the water comes in at and a zero pressure for the outlet
Fine mesh at the water level to capture surface effects as well as an appropriately small timestep size -  I've posted on some of the other free surface threads about some of this.
Message 3 of 9
OmkarJ
in reply to: apolo_vanderberg
Apolo,
If I may ask, is there any special treatment given to the advection terms for volume fractions, in terms of discretization scheme? This would be necessary for keeping the interface sharp, instead of smeared.
OJ
Message 4 of 9
Thanks for the reply. I am just now getting into CFD so pardon my ignorance. What do you mean by caded?
For now I am just getting used to the free surface application and moving fluid between volumes, and around steps. Much like in a flume.
Message 5 of 9
It might be better written as CAD'd, so within your CAD system, placed into a large domain.
A flume would be different though as you need no initial water level - just a really good mesh.
Message 6 of 9
Yes, sorry as Jon mentioned CADed / CAD'd - done in cad.
Omkar, we do have a smoothing algorithm applied to the VOF=0.5 to help with rendering of the results.
I dont specifically have the details as to what terms it is applied to at the moment.
Message 7 of 9
OmkarJ
Thanks, I assume that mostly, this would be a transient simulation -meaning, mesh adaptation is not possible (I guess?). How do you suggest one should determine the mesh size to capture the interface adequately? And what about timesteps - perhaps Intelligent Solution Control is necessary here always?
OJ
Message 8 of 9
Jon.Wilde
in reply to: OmkarJ
Hi Omkar,
Yes, all Free Surface analyses must be transient. We suggest a uniform mesh on the water surface and then I tend to apply a region around the boat and wake, in a section of the air and water with a finer mesh.
CFD will control the timestep after it is running, I would still start small though, maybe 0.01 of a second, which is what I used on my last hull model.
Message 9 of 9
If you want a full detail regarding this designs. I recommend you to use Maxsurf.
Thanks and Best regards,
~Mac
Lifting Structural Engineer / Naval architect engineer
