CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
CFD crash on each start
3 REPLIES 3
Michael.Koch
551 Views, 3 Replies
i have a big problem with CFD after we changed some hardware (SSD) and installed Win7 (Prof 64bit).
CFD crashes on every startup with an error (picture). I already installed SP1 and disabled the TabletInputServices but still nothing works. We are running CFD 2013 on 4 different Computers (XP,Win7,...) with no problems.
There is also a problem with the start of inventor, here nothing happens (no program and no errors).
Anyone an idea?
Thanks for reading and help
3 REPLIES 3
Royce_adsk
in reply to: Michael.Koch
There is an active case open with support regarding this issue.  We will try to update the forum with the resolution.
Royce.Abel
Technical Support Manager
OmkarJ
Just yesterday I encountered the similar problem in Inventor as I was greeted with the similar error window.  With all efforts in vain, I used the age-old solution for most software problems: uninsitall-install. And it was alright. Took me few minutes but at least I resumed work!
Don't know if SimCFD responds similarly though.
OJ
Royce_adsk
in reply to: OmkarJ
When I uninstall and reinstall when there are running issues I like delete the following folders after uninstalling.
C:\Program Files\Autodesk\Simulation CFD 2013
C:\Users\%username%\AppData\Local\Autodesk\Simulation CFD 2013
C:\ProgramData\Autodesk\Simulation CFD 2013
When you install the next time make sure you right click on the installer and pick 'run as admin'.
Royce.Abel
