Using SimCFD 2013, I ran a CFD scenario and while it was running, I kept an eye on the run using the CFD Solution Monitor. But when the scenario ended, the entry in the Solution Monitor "Design 1/Scenario 1 has finished successfully" did not disappear like it usually would. After I saved and closed both the SimCFD 2013 and Solution Monitor, the moment a new SimCFD 2013/Solution Monitor is launched, that entry comes back. I can run other scenarios without issues, but that entry is slowly becoming an eye sore.
Is there a way to remove that entry?
If you want to clean the queue:
With CFD closed and no jobs actively running.
Open the ServerManager (Start - Programs - Autodesk - Simulation CFD - SimCFDServer)
Stop and then Start this service.
If you are running Vista or Win7 you will have to Right-click and "Run as Admin"
Once that service is restarted the queue should get cleared out
