Dear CFD Experts,
I kindly request you to support me in following issue:
I wanna transfer my CFD results of electronic cooling (Pressure+Temp) into Mechanical Simulation inorder to perform Structural analysis (deflection, fatigue due to thermal heat generation)
1. How to transfer CFD results ?
2. When I tried using RESULT-RESULTS TASK-FEA MAPPING---it asks for "FEA DECK = .INP" file, but I could not find any .inp file
Many Thanks,
Kind Regards,
Ajay.S
Solved by Royce_adsk. Go to Solution.
Solved by Jon.Wilde. Go to Solution.
Hi Ajay,
Have you tried this method?
http://vp.telvue.com/preview?id=T01885&video=147697
Kind regards,
Jon
Hi Ajay,
To map over the CFD pressure results to Mechanical you are going to have to leverage this application.
Thanks!
Royce
Is there any method to map pressures to Sim Mechanical 2013? From CFD 2013? The app says only good for v2014.
