CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
CFD 360 crashes during meshing
2 REPLIES 2
408 Views, 2 Replies
Hi -
I'm trying to run a simulation that includes a finely-finned heat sink, so the estimated elements with automeshing are over 1,100,000. All is fine until I start the solver, then it crashes with:
Mesher process started...
Loading model...
Loading mesh sizes and constraints...
Surface meshing... generating surface mesh
1103-100
Can anyone tell me what this error code means, and possibly how to avoid it?
Thanks!
2 REPLIES 2
derrek.cooper
Hi Olev.. Could be a few things. One thing to do as a sanity check is apply a course mesh and ensure you aren't running out of memory. The 360 memory capabilities are quite high, so just trying to rule this out.
Appears to be failing on the surface mesh, which could indicate the model has either complex surfaces or complex blends between surfaces.
Either way, probably would be more efficient to log a case to have one of the members of the team take a closer look
Derrek Cooper
Director, Inventor Products
in reply to: derrek.cooper
Hi Derek -
It crashes pretty quickly without using much memory, so I guess we can rule
that out.
I agree that this should be logged - it actually was a few days before, but
I hadn't heard back yet and needed to move forward somehow.
Thanks!
Olev
