CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Autodesk Simulation CFD License problems
4 REPLIES 4
idosbass
966 Views, 4 Replies
Hi there,
I am using Autodesk CFD 2013 under an education license because I am taking a CFD course over next summer and I would like to get some exoerience on the basics before I go in.
But when I installed the software (and reinstalled several times), with a standalone license, the program starts fine, and I can set all of my parameters and import geometry and all that jazz, but when I try to SOLVE, it says there is a "message from a background program" that says
Unable to initialize ADLM
error code <-104>
When I hit ok, it brings me back to CFD where it asks me to check to make sure my licpath.lic is in the installation folder, and if not, to add the following two lines to a blank .txt file and change the name to licpath.lic:
SERVER servername 0
USE_SERVER
with the name of my computer to be the servername. I have tried this, but it does not resolve the issue, I have also tried running the batch file to change the registry to en_US (although my registry was already set to that) and I have tried multiple iterations of the licpath file, using my computer name, 127.0.0.1, and even including my physical address where the 0 goes like would be found in a network license.
This has been really frustrating, especially since I got inventor 2013 to work flawlessly at the same time. Any ideas on how to fix this issue?
4 REPLIES 4
TravisNave
in reply to: idosbass
So if it is a stand-alone license, why would you be making changes as if it were a network version?  Are you running LMTOOLS locally for that product?  Are you running a mix-match of stand-alone and network seats?
Autodesk Forums:
idosbass
in reply to: TravisNave
It was installed as a stand-alone license, not as a network license, and I am only making the changes it tells me to try to make. I am running LMTOOLS, but I don't know why it got installed. It does not have a license file to point to, and when it is running it does not say that it has any servers running.
I installed Inventor just fine and it works ok, and like I said, the program Simulation CFD starts up and I can make changes and apply materials and initial conditions, but when I hit solve is when it tells me it is trying to launch ADLM and there is a failure. I have tried re-installing it multiple times by uninstalling Simulation CFD and reinstalling it, but is there any way to just completely remove ALL autodesk products and try again?
TravisNave
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Autodesk Forums:
robert.camilleri
HI, I was wondering if you had manage to resolve this issue.  thanks.
