Discussion Groups
Simulation CFD
OmkarJ
Anisotropic mesh gradation
145 Views, 3 Replies
09-27-2013 01:59 AM
I thought I read somwhere that SimCFD 2014 supports anisotropic transition from wall to internal elements for prism elements. I couldnt find much the reference of it in the doco. Is it there, and if yes, what is it?
Omkar
Please use plain text.
Product Support
Royce_adsk
Re: Anisotropic mesh gradation
09-27-2013 03:09 PM in reply to: OmkarJ
Hi OJ,
Do you mean the mesh enhancement gradation setting?
http://wikihelp.autodesk.com/Simulation_CFD/enu/2014/Help/0532-User_s_G532/0698-Process698/0719-Setu...
-Royce
Royce Abel
OmkarJ
09-30-2013 01:16 AM in reply to: Royce_adsk
Royce,
I do know about the gradation, and btw, this is a really good addition. What I was curious about is term "anisotropic gradation" and I think I saw its mention in one of your comments in the case I generated (08379075). For the sake of this conversation, let me put the excerpts of the comment here:
The future Y+ adaptation is through the general mesh adaptation option.  This does a much better job to generate a good mesh transition and couple that with SST and 10+ layers of wall elements with anisotrophic mesh transition from the wall and you can really start to get an excellent mesh.  When I am using Ke in 2014 I typically set a value of 100 or 150.  When using SST I will shoot for 100 or less depending on the number of layers that I have used and the amount of layer gradation.
Can you explain what exactly that is? Is it equivalent to "Edge growth rate" in the lateral directions? Or is it about the localised mesh adaptation for Y+?
Omkar
Product Support
Royce_adsk
09-30-2013 01:48 PM in reply to: OmkarJ
Ahh.. I remember that post.
You can use this flag (mesh_anisotropic_blend) to turn on anisotrophic blending. There are no real controls for the flag, but does allow anisotrophic elements away from the mesh enhancement layers to be generated.
Give it a shot with a simple model!  It can add a lot more mesh and take longer to mesh, but can be useful for some geometries.
-Royce
Royce Abel
