Discussion Groups
Simulation CFD
Active Contributor
pwilkins
Analysis that is run overnight completes, but freezes
152 Views, 1 Replies
04-30-2012 09:00 AM
Twice now in the past couple of weeks I have set up an analysis to run overnight and have come in the next morning to see that the analysis has completed (iteration box shows the full iteration count) but has frozen my computer.  These analyses were large (6.5 - 7 million elements), but were running fine when I left the office.  I am not sure what could be causing the problem since just two weeks ago before this malfunctioning began I successfully ran an analysis of this same size overnight.
What might be the cause?
Please use plain text.
Product Support
apolo.vanderberg
Re: Analysis that is run overnight completes, but freezes
04-30-2012 10:48 AM in reply to: pwilkins
Philip
    Typically if the model runs fine (while you're there) and runs in to issues overnight (while you're not), we may want to investigate if there are any processes that happen overnight that can contribute to the issue.
Some of these may include:
Mandatory Virus Scan, that may look at our temp files and interfere with the solver as we try to update the temp files
Backup software. Similar to the virus scan, if the backup process starts taking files we may get conflicting access to the temp files.
Encryption software / Updates: some IT require that drives be encrypted and if this process happens overnight, or IT happens to push out Windows Updates that force a reboot we can potentially get solver issues, or a reboot unknowingly.
Apolo
